 Oggetto del messaggio: Fiat Stilo Volante Problema instalazione comandos
Numero Post: 1 MessaggioInviato: lunedì 9 aprile 2012, 19:00
Allestimento: base
hi people!
I'm going crazy! I have installed the buttons on my steering wheel but I have a problem I do not know how to solve.
I added 3 cables, two for the CAN network and the other cable for lighting. The pins of the cables is correct and steering wheel commands work 100% but the problem is the lighting, when I turn the key to ON position, steering wheel LEDs are lit for 2-3 seconds and then turn off and when I play the horn occurs same. That is, the steering commands work properly but the lighting alone for two or three seconds and off.
I have connected every wires as electric scheme says:
-3 D47 --> 4 D097R
-4 D47 --> 6 D097R
-5 D47 --> CN+ ignition.
I tried connecting pin 5 after 4 seconds and the LED is off too after 2-3 seconds...
I don´t know why can occurs this problem but i don´t know what can i do...
I think that the problem can be the ecu of steering wheel??
seems that steering wheel ecu cut the electricity after 2-3 seconds....
any solution for my problem please??
 Oggetto del messaggio: Re: Fiat Stilo Volante Problema instalazione comandos
Numero Post: 2 MessaggioInviato: lunedì 9 aprile 2012, 20:50
have you seen this topic?
viewtopic.php?f=121&t=338&start=0&hilit=comandi+al+volante
Numero Post: 3 MessaggioInviato: lunedì 9 aprile 2012, 22:42
Allestimento: base
yes, i have seen this topic and i have already done all installation.
My problem is that steering wheels commands work 100% but only have lighting 2-3 seconds and after turn off...
i dont know which can be the problem but im going crazy...
Commands work perfectly but lighting of leds turn off when pass 2-3 seconds after i turn on my car...
any solution?
Numero Post: 4 MessaggioInviato: martedì 10 aprile 2012, 7:27
I think it's better to continue in the other topic, so we have all the informations there (also in case in future others have the same problem).
Please continue there, as you started. :ok:
Thanks you, i close this. :lock:
