Oggi è domenica 8 novembre 2026, 9:01
Apri un nuovo argomento Rispondi all’argomento  [ 27 messaggi ]  Vai alla pagina 1, 2  Prossimo
 Oggetto del messaggio: B103A airbag
Numero Post: 1 MessaggioInviato: giovedì 18 febbraio 2016, 10:43
Hi there. Need some help: I currently have a problem with the air bag, as the trip computer indicated to me faulty airbags.
Three light is on: belts, defective airbags, passenger airbag, flashing kilometers.
Airbag Control Factory "51827584" exchanged their son in the new Code: 51,873,888th
Now it has two light is on: belts, defective airbags, and an error code: B103 front crash sensor error. Message: "error cause the controller does not receive a signal from the sensor"
I bought a new sensor. The error will continue to arise.
 Oggetto del messaggio: Re: B103A airbag
Numero Post: 2 MessaggioInviato: sabato 20 febbraio 2016, 12:08
it's hard to figure out your problem, however controls the wiring of the front sensor , it may be damaged
Numero Post: 3 MessaggioInviato: sabato 20 febbraio 2016, 12:49
See the wire. Before I changed sense of sight. How many were there to be a line? Konktakt spray all connections?
Numero Post: 4 MessaggioInviato: sabato 20 febbraio 2016, 12:52
thanks for the reply. I do not know what could be the problem. Maybe their connections have to look everywhere.
Numero Post: 5 MessaggioInviato: lunedì 22 febbraio 2016, 13:28
The airbag warning light came on due to an accident ?
Numero Post: 6 MessaggioInviato: lunedì 22 febbraio 2016, 14:05
Hello
It was not an accident. When driving, it was a mistake after a pothole. It has been there. Everything has been viewed. new control new collision detection. Proxy settlement ??
Numero Post: 7 MessaggioInviato: lunedì 22 febbraio 2016, 15:30
It happened after a pothole, was very deep? Perhaps you have disconnected the airbag wiring or there is a bad contact
before making a settlement proxy, you must be sure that the plugs and wiring components are ok
Numero Post: 8 MessaggioInviato: lunedì 22 febbraio 2016, 15:49
Hello!!
Yes, after a pothole came up with everything. half years ago. He has been given a new airbag control unit. After another error code readout "B103" error, "FRONT CRASH SENSOR". Now I crash into another Sensor. All the same it was nothing changed. Today I checked all connections. But nothing changes.
Idea??? What do you think could be the problem. I had a clerk here because Hungary has not met this problem. Can you help me with what I watch. You may be a current sensor wiring was how many?
The error code reading program showed this also:
the cause is that the controller is not receiving a signal from the sensor, the error is still above
Numero Post: 9 MessaggioInviato: lunedì 22 febbraio 2016, 16:13
It was a factory driver: fiat 51827584
This was replaced by fiat 51851217
The FIAT EPER this "51851217" has to be replaced with.
I do not know how to insert pictures.
You can put it up here might say something to you
Numero Post: 10 MessaggioInviato: lunedì 22 febbraio 2016, 20:30
before you wrote that flashes the odometer, it is still flashing? the flashing of the odometer usually occurs when the bodycomputer does not recognize a control unit or is installed an apparatus not provided as standard, or when there is a temporary lack of electricity. After taking the pothole, in addition to the lights on, you found other strange things?
Numero Post: 11 MessaggioInviato: martedì 23 febbraio 2016, 7:25
the mileage account is still flashing. this driver has changed so much that when it was packed in the car disappeared in the passenger seat légzság error. Now only a red light. thanks anyway feeds. probably will not accept this control in your car ?? What do you think should be done ?? out to the field and then set fire ???
Numero Post: 12 MessaggioInviato: martedì 23 febbraio 2016, 13:44
the odometer flashing even before the pothole? you've installed something different from the envelope for car series?
if the odometer flashes after pothole means that something is disconnected temporarily, and now is not recognized by bodycomputer. Sometimes it happens even if the battery terminals are slow, or if the battery is no longer good for safety also controls the alternator connection. In modern cars when the electricity is not just all hell breaks loose, so you should double check the battery, alternator and their corresponding terminals ;)
Numero Post: 13 MessaggioInviato: martedì 23 febbraio 2016, 14:50
the potholes in front of the mileage counter is not blinking. After a pothole at high speed belemntem interest, and then they came to these errors. Old controller: pretensioner error, AIR BAG FAILURE, FRONT PASSENGER AIR BAG / SIDE BAGS DEACTIVATED, SEAT BELTS NOT Fastenal and kilometer counter flashing. She got another controller, these were: AIR BAG FAILURE (RED) message: airbag failured see handbook. or counter flashing kilometers.
You have a generator, battery check over.
Numero Post: 14 MessaggioInviato: martedì 23 febbraio 2016, 21:40
oh my god..! :huh: But you get in a volcanic crater ?? :o:
then probably the airbag system detected a strong deceleration and airbag safety system has intervened, but the front and side sensors have not heard a bump and then the airbags are not exploded. Now the diagnostic failured airbags and flashes the odometer, right? then the odometer flashing means that a control unit (air bags) is not recognized by the body computer, the computerized diagnosis should also say what does not work
Numero Post: 15 MessaggioInviato: mercoledì 24 febbraio 2016, 8:11
Yes. Flashing lights on the odometer and the air bag lamp. After start beeping for about 5 seconds. then the message. failured airbag. The passenger airbag can be switched off. if you turn it off immediately shown on the dashboard that is turned off. It works. you probably will not recognize the driver? It has the item number Avenue has nowhere to sell. the program also brings this out. You can sort proxy ?? Or some other solution ??? What can you do ?? Thanks for the help so far.
Numero Post: 16 MessaggioInviato: mercoledì 24 febbraio 2016, 10:37
probably a good control of the air bag, just the computer does not recognize the body ??? I say the odometer flashing, the airbag light is on. DTC B103 front crash sensor. After all, this error code can be standardized at three errors. I do not know Body computer ??? Battery?? Wires ?? Connectors ??? or sensors ??? I wrote a short list of what you think look at exactly ??? I'd appreciate. You can not control that communicates to the body computer?
Numero Post: 17 MessaggioInviato: mercoledì 24 febbraio 2016, 10:53
maybe that's the problem ??
Old controller: Serial Number: 51827584 VDO
New Controller: Serial Number: 51851217
In the new controller was not "VDO" message
Numero Post: 18 MessaggioInviato: mercoledì 24 febbraio 2016, 11:10
body computer upgrade.
I've never had since I have the car.
Since the new age of 8 years
Numero Post: 19 MessaggioInviato: mercoledì 24 febbraio 2016, 11:58
do a bit of clarity ^_^
then, the steps are these:
check the battery and its terminals
Alternator Control and its terminals
checked wiring and plugs around the air bag system
Now, if these checks are successful, proceed like this:
connects the computerized diagnosis and identifies the exact error and the component that is causing the error (active passenger airbag, through its switch, before making the diagnosis)
try doing a proxy array, in case of failure you have to proceed to change the diagnostic component identified
after changing the component, again performed the diagnosis and resets the error list, then proceed to the alignment proxy of the airbag system
Numero Post: 20 MessaggioInviato: mercoledì 24 febbraio 2016, 13:44
okay
thanks for the information. It will mark what we got
I have looked over all of the passenger compartment connector.
The cable controller found a body I could move easily by hand. As if it were a few torn fibers in the cable lug
