Oggi è sabato 7 novembre 2026, 7:56
Apri un nuovo argomento Rispondi all’argomento  [ 219 messaggi ]  Vai alla pagina Precedente  1 ... 3, 4, 5, 6, 7, 8, 9 ... 11  Prossimo
 Oggetto del messaggio: Re: Bravo ax1yz: special car "la cavia elettronica"
Numero Post: 101 MessaggioInviato: martedì 19 luglio 2011, 20:01
L'igo9 non ti conviene perchè i driver per il gps non sono ancora stabili, tempi molto lunghi prima di fare il fix dei satelliti <_<
Numero Post: 102 MessaggioInviato: mercoledì 20 luglio 2011, 22:17
Allestimento: Sport Drive
ax1yz ha scritto:
Sepher Hello, sorry but I do not write English :azz: and use "google translator" :lau:
Thanks for the compliments :rolleyes: , if you want to translate the guides for your friends, no problem, go ahead :ok: .
The steering wheel should not be connected in parallel because the voltage sent from the computer take precedence over the one-body of the car, I had to try, but then I gave up in the radio because I have everything I need, so I excluded B & M .
I'm sorry I've never bought CAN bus interface because they cost too much, and are not standard
@ simon_27, corry88, jefe75 e si specialmente questo G2216 :D
Ale ma ci facciamo dare la percentuale, che ne dici :shifty: :lau:
Hi ax1yz,
Hmm, I'll try google translator :)
Thanks, I translated your tutorial in Turkish Bravo Fans forum hoping many of us profit from your know-how.
Later I figured it out, also. Tested the HU using a PC power supply and found out that the unit acts as a constant current source (which is very low indeed ) on SWC pins. So as you said, either the body computer or the HU will overload or suppress other. So, in case I cannot find a suitable can-bus adapter I will develop a circuitry that would probe the lines and translate the button presses to head unit. A simple PIC MCU with analogue input will be enough.
Again thank you very much for the information, patience and of course your comprehension for me typing in English.
Best regards,
Numero Post: 103 MessaggioInviato: giovedì 21 luglio 2011, 7:28
Hi sepher :wel:
if you wish you could make us an official introduction, so everyone can give you his wellcome..
You can open a new presentation topic in tis area (viewforum.php?f=2)
:wel:
For your problem i think it is better to discuss here viewtopic.php?f=122&t=20300&p=650993#p650993 which is the specific topic for steering wheel controls. :ok:
Numero Post: 104 MessaggioInviato: domenica 24 luglio 2011, 23:39
momonedusa ha scritto:
Hi sepher :wel:
:wel:
Hi momonedusa,
Job done! Thanks for the link.
Thanks for your recommendation. I gathered some useful information on relation between Chinese branded head units and Pioneer. I will try to explain my pre-mature conclusions on that topic.
Regards,
Numero Post: 105 MessaggioInviato: martedì 6 settembre 2011, 16:42
Motore: 1600 mjet 16v 90
Complimentoni per le modifiche all'auto.
Io già sto in crisi per installare l'autoradio nuova...e da norauto mi hanno chiesto 200 euro di manodopera....
:incazz: :incazz: :incazz: :incazz:
Fiat New Bravo 1.6 m-jet 90 cv
Numero Post: 106 MessaggioInviato: domenica 16 ottobre 2011, 9:30
ops... scusa spa856, ho visto solo oggi la tua risposta, grazie :D
200€, se sono solo per sostituire l'autoradio sono tanti, se invece devi aggiungere moduli o cablaggi vari... bisogna valutare ;)
Comunque oggi con quasi 25000 Km sulle "gomme :lau: " e il secondo compleanno della :bravo1981: :wub: , avevo un Immagine per oggi, se non fosse per gli incompetenti dell' SDA :azz: non sanno leggere neanche il civico di una via :incazz:
Numero Post: 107 MessaggioInviato: domenica 16 ottobre 2011, 10:00
Metti luminoso anche quello Anto :P
Augurozzi :brinda: è la stessa cosa mia? :shifty:
L'INACIDITO
Numero Post: 108 MessaggioInviato: domenica 16 ottobre 2011, 10:13
:ot: Se posso dirtelo non andare da Norauto...a me di manodopera me ne hanno chiesti 80 presso un installatore autorizzato...fai un pò di preventivi in giro ;) :ot:
Numero Post: 109 MessaggioInviato: domenica 16 ottobre 2011, 10:18
No Paolo, quelli che metti tu, li ho da quasi un anno e mezzo, grazie ad Ale :B): però potrei farli anche luminosi a led :rolleyes:
Numero Post: 110 MessaggioInviato: domenica 16 ottobre 2011, 10:24
:azz: Allora mi son perso le foto :unsure:
L'INACIDITO
Numero Post: 111 MessaggioInviato: domenica 16 ottobre 2011, 11:18
E scritto anche in firma :rolleyes:
Numero Post: 112 MessaggioInviato: domenica 16 ottobre 2011, 13:58
Modello: * coupè/cabrio
Forse saranno gli specchi elettrici????????? :o: :P :lau:
Numero Post: 113 MessaggioInviato: martedì 29 novembre 2011, 19:12
Forse iniziano a funzionare come dico io :shifty: finalmente :azz:
Numero Post: 114 MessaggioInviato: martedì 29 novembre 2011, 19:22
fantastico ax1yz :brinda:
Fiat Bravo 1.4 90cv GPL Dynamic grigio Bel Tenebroso Ordinata il 04/04/2009 ~ Arrivata il 15/07/2009 ~ Ritirata il 16/07/2009
Optional: cerchi in lega 16'' 20 razze, radio mp3 4 altoparlanti + 2 tweeter con comandi al volante, Blue&Me + usb, clima manuale, interni Inox Grigio Antracite, impianto GPL Landi Renzo, kit gonfiaggio
Modifiche: Anabbaglianti xeno 5000k, abbaglianti NightBraker Plus, lampade fendinebbia 4400k, posizioni, luci targa e illuminazione baule a led, rimozione portatarga posteriore, antenna corta originale Lancia Phedra 5cm, protezione baule, tappetini personalizzati Sontizio, filtro sportivo Bmc
Numero Post: 115 MessaggioInviato: martedì 29 novembre 2011, 19:31
Anto...sei semplicemente un mago :clap:
L'INACIDITO
Numero Post: 116 MessaggioInviato: martedì 29 novembre 2011, 20:07
ben fatto ...... sei proprio un elettronico in tutti i sensi , oltre al nik intendo .... :ok: :D
______
Numero Post: 117 MessaggioInviato: martedì 29 novembre 2011, 20:10
Grazie raga... :B):
LIROID80 ha scritto:
nik elettronico
Questa mi mancava :lau:
Numero Post: 118 MessaggioInviato: martedì 29 novembre 2011, 20:17
Antonello, hai l'auto posseduta, muove parti da sola! :o:
Bel lavoro! :ok:
Numero Post: 119 MessaggioInviato: martedì 29 novembre 2011, 20:19
Sei veramente un grande!!! :ok:
La mia bimba...
Numero Post: 120 MessaggioInviato: martedì 29 novembre 2011, 20:21
Se riesco domani faccio un filmato un pò più distante :rolleyes: stò rivoluzionando l'impianto elettrico :D pensa che non mi basta più una DB9, ne ho dovuto aggiungere un'altra :azz: e devo ancora ripristinare l'accensione fari ecc. :lau:
muove parti da sola
La prima Bravo dumbo :lau:
